I recently found a 2011 PCX 150 here in South Florida on Craig's list, with 6666 miles on it, with a rear worn out smooth rear tire....
Tickled to be on my new steed, I ordered a new rear tire, along with some body panels to fix this bike up.
(I've been dealing with Honda minis, since 1972, having restored over 20 bikes, so I have some experience and all the tools...)
I'm waiting on delivery of my shop manual, so what the hey, how hard can a rear wheel job be? Besides, I did watch the you tube video.....
Everything went great, until I tried to remove the swing arm, to gain access to the rear wheel removal.
STUCK, and I mean REALLY @#$%!#$ STUCK.
The inner race of the bearing is seized on the spline output shaft.
I had a nice 1 1/2" thick block of aluminum, that I drilled up, to mount on the muffler holes of the swing arm, and tried reverse press the swing arm off the output shaft:
Wouldn't budge. No damage to scooter, but there was enough torque applied, that it began to damage the bolt used to apply the pressure on the output shaft.
Recommendations to community:
1. - If you are looking at a used unit, with a bald tire, have the current owner get a tire put on it!
2. - If you current own a PCX, remove your rear wheel, and apply anti-seize compound to the area where the output shaft meets the inner race of the swing arm bearing.
So I had no choice yesterday, but to reassemble the bike, until I come up with a plan to deal with this issue.
Fortunately for me, I have access to a motorsports expert, who is 30 year mechanic at my local Honda shop. I'll post his recommendation, and continue my tail of woe once I begin to move forward.
Two thoughts I do have:
A: Use a slide hammer with my aluminum piece.
or
B: Disassemble the transmission and drive the output shaft with a hammer and brass drift pin, once the final gear is free to slide out, when the transmission cover is removed.
So it begs to be asked: Has anybody dealt with this issue?
Thanks bunch for your time....
