Breaking in period
- Joemag22
Breaking in period
Hey everyone,
I'm new to the PCX world and this forum. I just bought a 2011 PCX 125 with only 170 miles on it and I'm trying to catch up on all the threads and information here... My scootz came with the j.costa vari and j.costa exhaust, not my choices, but I had no idea and it has some good pick-up and go. Since everything is brand new I'm looking for some tips on the breaking in period so I can enjoy this as long as possible.
Thanks!
Thanks!
Current: 2011 Honda PCX125 (j.costa vario and j.costa exhaust)
Past: 2008 Honda Met (Dayton drag vario, CDI box, spark plug, kn filter, and a cup holder)
** NOR-CAL / East Bay Met Set SC **
Re: Breaking in period
Just ride it normally avoiding full throttle starts for the next two hundred miles or so and get the first oil change and oil screen clean at 600 miles and all will be well.
- Joemag22
Gn2 thanks for the response. That seems simple enough
gn2 wrote:Just ride it normally avoiding full throttle starts for the next two hundred miles or so and get the first oil change and oil screen clean at 600 miles and all will be well.
Absolutely agree. The only thing I would add is to change the rear drive oil at the same time.
- Joemag22
I can do that too. Just got back from an 80 mile trip with my fiancé. Great ride, not a lot of wind, but I'll def be looking into the windshield soon. Some pics will be posted in the gallery too. Thanks you you
Do NOT forget to adjust the valves. They should be checked and adjusted if need be at the 600 mile and the 1200 mile services. After that you can pretty much forget them.
- Joemag22
Ooooo, are valve adjustments difficult or should it just be brought into a dealership for that? I like the idea of being mechanically inclined, but reality is always a little different....
21,000 miles on my PCX, runs good as new, getting 100mpg, and have never had the valves inspected......
Ours were out of adjustment at our 600 mile and 1200 mile checks. Since then we havent touched them. It is part of the service, but it is up to you as to whether you want to do it or not. I would at least check them, but that will require taking off a lot of plastic. That is the reason for the high service fees.
- katschamne
I just had my 600 mile check and they had to adjust the valves as well. When I went to pick up my scooter they weren't done with it yet. Amazing how much they have to take off. Only they very front part was still in intact. The rest was down to the frame. I was charged $290 for it. My husband's first oil change will be $125 for a Kawasaki Vulcan Vaquero.
So, Honda dealers can't use the 'take the seat and a few other bits off and reach down' trick - it was posted this was a much easier way to do it. Strange you got charged so much - it can be argued the valve check is part of the first service and should be right from the factory, and most dealers charge around £70-90.katschamne wrote:I just had my 600 mile check and they had to adjust the valves as well. When I went to pick up my scooter they weren't done with it yet. Amazing how much they have to take off. Only they very front part was still in intact. The rest was down to the frame. I was charged $290 for it. My husband's first oil change will be $125 for a Kawasaki Vulcan Vaquero.
I am intrigued by this "take off the seat and a few other bits and reach down" method. Could anyone please share a link to it?
- Alibally
Dittoadambee wrote:I am intrigued by this "take off the seat and a few other bits and reach down" method. Could anyone please share a link to it?
A simpler method was explained in this thread - no seat removal just under seat shroud and bits.
http://hondapcx.org/viewtopic.php?f=19& ... lit=+valve
http://hondapcx.org/posting.php?mode=quote&f=19&p=31328
scisor34 wrote:21,000 miles on my PCX, runs good as new, getting 100mpg, and have never had the valves inspected......
Bahahaaha... Here I am at 2,000 miles and I was feeling bad for not having them adjusted yet.
There is a general consensus here that the maintenance interval specified by Honda are a bit conservative.
Current - 2015 Honda CBR650F
I ownder if they just went with the sound of it and how it started - doubt many dealers take off lots of plastic just to have a look, esp. as many have posted their dealer stated they don't unless needed.katschamne wrote:I just had my 600 mile check and they had to adjust the valves as well. When I went to pick up my scooter they weren't done with it yet. Amazing how much they have to take off. Only they very front part was still in intact. The rest was down to the frame. I was charged $290 for it. My husband's first oil change will be $125 for a Kawasaki Vulcan Vaquero.
- katschamne
I'm not sure why so much was off. I did have an problem last year with my belt that I wanted them to check because I didn't trust the other dealership I had fix it. At the time I walked in they were just doing the valve adjustments and oil change. I agree I think the valves should be right from the factory, but after you start riding you break in the parts. I think the first 600 mile check up should be included in the price.
