Is this a good deal?
I found a used 2011 PCX 125 for $1200 OBO. However, it has 25,000 miles on it. Used for a daily commute. If it is clean, never laid down, etc. would you folks think that this is a good deal?
Re: Is this a good deal?
Welcome to hondapcx.org. It would be a lot easier to answer that if we knew where you lived. US, Australia, Canada? You mention $'s so I'm thinking it is one of those three.ghosteye wrote:I found a used 2011 PCX 125 for $1200 OBO. However, it has 25,000 miles on it. Used for a daily commute. If it is clean, never laid down, etc. would you folks think that this is a good deal?
Yes.ghosteye wrote:I found a used 2011 PCX 125 for $1200 OBO. However, it has 25,000 miles on it. Used for a daily commute. If it is clean, never laid down, etc. would you folks think that this is a good deal?
Don't be afraid of the miles. I have 23,000 miles on my 2013 PCX150 that I also use as a daily commuter, runs and rides like when it was new. Ask if he they have any maintenance records. If not, and it starts and rides smoothly, who cares it's a bulletproof Honda. I say buy it.
I am located in the US. In California. Thanks for the feedback.
Buy it quickly.
Oh hell yes, jump on that deal. If it runs and doesn't sound like hell, it's probably solid, and sounds like a great deal.
What are you doing? Stop reading this forum, go buy it. If I saw one that cheap, I'd go buy another even though I already have one.
Only thing to worry about when buying used would be the centre stand mounts on a pre-eSP model.
Other than that if it runs and doesn't sound rough, it'll probably be fine.
- Alibally
I agree. A workmates just bought a 2011 v1 and the stand is seized solid. He keeps spraying it with penetrating oil but is cautious about moving it incase the lugs break causing a leak.gn2 wrote:Only thing to worry about when buying used would be the centre stand mounts on a pre-eSP model.
I would be tempted to just cut through the stand leaving the pivot in place and discard the rest in case someone tries to use the stand.....
Seconded.gn2 wrote:I would be tempted to just cut through the stand leaving the pivot in place and discard the rest in case someone tries to use the stand.....
I removed my centerstand, and never plan on reattaching it.
Dang, I bet it was sold already. No reply to my email.
