Inflating cold/hot tyres
anavi13
Post by anavi13 »
Hi,
just a quick question:
Am I right in thinking that when inflating 'warm' tyres I need to aim for pressure that's slightly higher than the recommended 29/33 psi?
I got a very simple digital pressure gauge today, went to check the tyres on my parked pcx and found it to be a bit lower than it should. To inflate the tyres I have to ride a couple of miles to my local petrol station and use the air pressure hose facilities there, as I don't have an air pump. I don't want to over-inflate but by the time the tyres have cooled down again the pressure will go down a little, right?
Many thanks
Urbanfreestyle
Year: 2014 (UK)
Re: Inflating cold/hot tyres
Post by Urbanfreestyle »
that is what i would do. obviously warmer air takes up more space thus more pressure.
Honda PCX 125 ESP (Black)
Get yourself a foot pump or a cycle track pump.
anavi13
Post by anavi13 »
gn2 wrote:Get yourself a foot pump or a cycle track pump.
Thanks, probably will. Although I guess the obvious thing would be to go check the pressure again and let some air out if needed, once I've come back from the petrol station and been parked for a while :)
Urbanfreestyle
Year: 2014 (UK)
foot pump / Track pump would be a PITA, i would say ride there gently, relax for a bit, then do the tyres. Don't think it'll make masses of difference. a little over-inflation won't hurt!
No.
The obvious thing is to get your own pump.
Track pump isn't a problem, a few strokes is all it will ever need.
Urbanfreestyle
Year: 2014 (UK)
it's all i need ;-P
I agree with gn2, buy an air pump. I have a Slime and it works great. Scroll down this page for pics: http://www.hondapcx.org/viewtopic.php?f ... t=Air+pump
I have had many vehicles in my life, and have made it a self taught rule to always check tires while cold. Accuracy counts (in my book). :? Anal, remember?
My tires carry my life on their treads. Think about that.
I check the pressure every two weeks on my scoot and monthly on my truck. I then plus or minus to the manufacturer's suggested pressure. Be aware that changes in climate temps affect your tire pressure as well. Be Safe(r), ck. them. They're easy habits to develop (I hope you care to) :P
And......a very good tire pressure gauge will help too. Invest in proper tools.
Oopsie....forgot to Welcome you. Sorry fellow PCX'er, Bizz got the best of me this time :|
Glad you found your way here, Cheers!
anavi13
Post by anavi13 »
WhiteNoise wrote:And......a very good tire pressure gauge will help too. Invest in proper tools.
:) Thanks very much! I do care, though at the age of 32 this is the first vehicle I've owned so all of the technical stuff is, unfortunately, a bit of a mystery. Hence joining here and trawling the forum for useful info every day!
Excellent!!!
We will help and guide you the best we can! Keep that in mind, okay? ;) "No" question is silly. Ask away!
So many adventures in life await you! Grab onto those Happy times and roll with it! :P
anavi13
Post by anavi13 »
WhiteNoise wrote:Excellent!!!
That's the plan! :D
anavi13 wrote:Hi,
Many thanks
Don't worry about it too much. Just pop some air in if the tyres need it.
binje
Post by binje »
I use a digital tyre inflator that I got from Halfords. Use it for the car and the scoot as well. It runs off the cigarette lighter so would only be useful to you if you have the new PCX with the power outlet in the glovebox. Mine being the older one, I just park it next to the car and run the pump from the car. I check pressures every other week on the bike just to be on the safe side.
2011 Honda PCX 125
When I was in Lidl on Sunday they had cycle floor pumps for a fiver, if you're quick they might still have some.
