Crank Case hose?
Crank Case hose?
What is this little un-connected hose coming from the crank case? It was shoved up into the breather box via that little channel and apparently open ended. Unless I pull it loose from something inside the airbox.
Re: Crank Case hose?
homie wrote:What is this little un-connected hose coming from the crank case? It was shoved up into the breather box via that little channel and apparently open ended. Unless I pull it loose from something inside the airbox.
It's the final drive gearbox breather I think
Oh no - they left some of you bike off! (only kidding) :)
