Side Stand Switch.
				Drifter
- Year: 13
- Color: red
Side Stand Switch.
Any one know how to disable the switch so it does not kill the engine.
I know its not a good idea because if you take off with it down you could crash. Learned that lesson many years ago!
- MikeP
- Color: White /red
Re: Side Stand Switch.
Hi Drifter, I just tried to reply to your PM, it is sitting in my outbox. How do I send it? Thank you
						- dasshreddar
- Year: forzaruckuspcx
Cut the two wires going to the switch and connect the two wires together.Drifter wrote:Any one know how to disable the switch so it does not kill the engine.
- OriginalRocket
What dasshreddar said.  I've confirmed from another post a while ago.  This is a winter project for me.
I know its a safety feature for most, but my daily use, I am having double the engine wear (start up) on the machine. And I have the 2011 model, with the known weak center stand hinge/engine case cracking.
Don't start it till you are sitting on it and ready to ride away.
Simple when you know how.
				Drifter
- Year: 13
- Color: red
Thanks Guys!  How do you get the bottom pan off to gain access to the switch?
I have a gate and shop door to open so 4 starts and stops each time i leave PITA this should cure the problem.
gn2 wrote:Don't start it till you are sitting on it and ready to ride away.
Condescending, and you know how.
The bottom pan's a bit of a hassle, but the bottom left and right panels are easy to remove. It's covered in the dismantling guide, about halfway down. You can remove the lower panels without removing the seat or back panels: http://hondapcx.org/viewtopic.php?f=3&t=2630Drifter wrote:Thanks Guys! How do you get the bottom pan off to gain access to the switch?
Pics for how-to:
Currently ride:  Nothing right now - mostly mountain biking with my boys until they're old enough to ride
				Drifter
- Year: 13
- Color: red
Thanks MD!!!!
You can take the switch off the side stand. Have the side stand in the up position. Try to start the bike to make sure it is in the right position. Then tape the switch so it can't move from that position. Put the switch out of the way. Now you can put it back on easy and no wires to cut or splice. I have run 2 other Hondas this way for 3 years with no problems.
				Drifter
- Year: 13
- Color: red
Wires have been cut and tied together works great!  PCX man good idea but to late....either way side stand down and the engine runs!!
- onemac
I use a trick to kill off the side-stand with this very useful YouTube video right here: https://www.youtube.com/watch?v=cfSJAnt3-dE
I wana start my PCX without to use to pull the left rear break lever. Anybody know a trick?
Wow, that's easy!
Great "How To" for those who want to do this. Thanks onemac for finding it, and thanks to the gent who put the video up. That's a Nice 2016 Red he's got
- honkerman
Just a word of warning, be careful of this kind of modification. The PCX like all CVT scooters is always in gear, since there is no neutral setting. Harley's have no side stand switch and many a Harley has been dropped because some numb-nut started it while it was in gear and on the side stand. Don't be like those Harley owners.
