Givi E370NA Matte Black & Givi SR1136
- tbln930
- Year: 2013 PCX 150
Finally ordered up a top case and rack for the PCX after much consternation. Not sure on the light set yet but I will probably go AdMore.
SECoda/tbln930
SECoda/tbln930
- tbln930
Re: Givi E370NA Matte Black & Givi SR1136
Revzilla.com just messed up my order. I received the metal racks for the top case mount but not the plastic plate. Now they are trying to find one to send me overnight for the weekend. Oops.
SECoda/tbln930
SECoda/tbln930
- tbln930
It turn out only their description was in error. The plate comes with the case.
SECoda/tbln930
SECoda/tbln930
- tbln930
Arrived. The latch works great on this one (seems to be an issue on some). The E370NA more closely matches the V47 on my Forza. Construction is more than robust enough.
SECoda/tbln930
SECoda/tbln930
FromMototoScooter
Had a similar model on an sv650 once. When it rained, water found its way in. Have you had similar problems with the one on your Forza? Let us know if this one leaks - I may have just had a bad apple- thinking about adding this to PCX - pics please
looks pretty sweet so far!
- tbln930
Ride in rain?
I fly my home built airplane in rain but riding in rain is too risky for me. I am a big chicken. In all of the reviews I read on both I never saw that mentioned as a problem but if it rains hard enough and long enough anything is possible.
I takes pictures on the install. Maybe I should do a video because I saw one guy trying to use a hand drill on the panel.
SECoda/tbln930
SECoda/tbln930
- tbln930
Took a few pictures of the setup before installation to study the case size proportion to the bike. The rack on the PCX version is a bit hokey compared to the Forza which looks a bit tidier in design. It is mainly hidden so not significant. IMO there is not enough room on the rear seat to install the Givi seat cushion. I may add one that is only about 1/2" thick.
SECoda/tbln930
SECoda/tbln930
- tbln930
The only skill required at all on these installs is getting the panel (get the panel removal tools) off and the drilling. A drill press and some masking tape to prevent chips and scratches makes it a piece of cake. I am still trying to find bright tail lights. I tapped into the wires previously for the KnightR light install. I spoke to AdMore and said I would buy their lights again but everyone says they aren't bright enough. Waiting to hear back from them.
On the SR1136 rack the support tubes are 5/8" diameter so I just made 3/4" holes using 5 different bits in increasing size. It took a good 20 minutes.
After that assembly and installation was 10 minutes.
SECoda/tbln930
SECoda/tbln930
- tbln930
SECoda/tbln930
SECoda/tbln930
tbln930 wrote:Finally ordered up a top case and rack for the PCX after much consternation. Not sure on the light set yet but I will probably go AdMore.
Do you have the part numbers?
- tbln930
http://www.revzilla.com/motorcycle/admo ... 70-topcase
http://www.twistedthrottle.com/admore-l ... 70-topcase
http://admorelighting.com/store/index.p ... uct_id=154
you you wrote:tbln930 wrote:Finally ordered up a top case and rack for the PCX after much consternation. Not sure on the light set yet but I will probably go AdMore.
SECoda/tbln930
SECoda/tbln930
- tbln930
SECoda/tbln930
SECoda/tbln930
- Alibally
Hi, there. I'm wondering about bying Givi B47 top case and after gathering information about how to install it, it's not clear for me - does installation need that givi SR1136 (or e231) mounting rack or is it possible go with included universal mounting kit?
tbln930 wrote:http://www.revzilla.com/motorcycle/admo ... 70-topcase
Cheers
