It says right there, if the fluid level is low you need to check your brake pads. Brake fluid doesn't leak, or evaporate, or otherwise vacate the system. If it would, your brakes would not work at all because there would not be enough hydraulic pressure. What has happened is that the brake pistons rest slightly further out of the brake calliper (closer to the disk), because the brake pads have worn. Take a flashlight and have a good long look at your brake pads. If you're not sure that they're ok, replace your pads.
You say in another post that you've done 3000 miles but not had a service. The first service is at 600 miles then 2500 then every 2500 after that. If you miss these services you won't be getting your scoot checked over properly, also you will invalidate your warranty - get to the Honda dealer you bought it from as soon possible. You must get your service book stamped if you want to get a good price when you come to sell in the future.
Worn out pads at 3000 miles seems too soon to me. I've done well over 6000 and mine are fine.
Entirely dependent on riding style.
And maintenance.
With single sided calipers, if the pins that the caliper slides across get dirty or corroded and the caliper does not move freely, the pad nearest the pistons gets worn away in no time flat.
This is why during winter it is essential to lift the front wheel clear of the deck and give it a spin.
If it does not turn freely, it's time to unbolt the caliper, pull the pins and clean up the sliding faces of the caliper and the pins, then whack on some copper grease, reassemble and you're good to go.
Alibally wrote:There's a small hole beside the ignition switch. You can see the level through there.
One day I'll shine a torch in that hole as in daylight all I ever see is a dark square, no level. Either I'm just not seeing the level line, or it's very full or too low
I know what you're saying iceman. When I went to buy my 2015 (on the showroom floor) I asked the salesman if there was fluid in there. I saw none. He looked and was puzzled. He saw none. Then he went to the rear of the scooter, lifted it off the floor (as I held the handlebar) and told me to look again. Wouldn't you know, I saw fluid! Yes, mine was filled to the brim and the fluid itself is clear. That makes it even harder to see when looking through the milky colored reservoir.
Maybe you want to try this lift technique out with another person ? Maybe your fluid will show itself? I hope so Oh! And have a pen type light available in case lighting is low.
My fluid was below the desired level so i took it to the dealer. The PCX mechanic said that the handlebars need to be turned all the way to the left before checking the fluid level. When i turned them to the left, the fluid was at the correct level.
yak wrote:My fluid was below the desired level so i took it to the dealer. The PCX mechanic said that the handlebars need to be turned all the way to the left before checking the fluid level. When i turned them to the left, the fluid was at the correct level.
That works for the level in the reservoir on the handlebars, didn't know it also worked for the CBS reservoir. Don't believe the user manual mentions this 'trick'.
I realize I am a great deal late to this forum, but...
I just did this today actually,
there are four pieces of plastic bodywork that you need to take off. The first two can be taken off in any order: the center piece where the gas cap is, there is one screw, and the piece below the handle bars to the left of the ignition switch. Then you should be able to remove the plastic plate around the ignition switch. Lastly, you have to remove the entire plastic piece behind that plate, there are two screws above the glove box, two above the ignition, and two by the gas cap, then there is one bolt in the middle.These pieces can all have fragile tabs (two were stuck and/or already broken).
After the PCX is open, the CBS fluid reservoir is where you would expect it to be. Is bled with the rear brake lever and the bottom bleeder valve on the front brake caliper.
