Kickstarter. Why isn't it stock on our bikes?
- dkazzed
- Year: N/A
Re: Kickstarter. Why isn't it stock on our bikes?
I think it was because it's not recommended with fuel injection.
2015 Honda CB300F ABS
- GeeGusKahn
Fuel Injected bikes and scooters don't come with kick starters.
Part of problem is you have to have a minimum voltage at the battery or the ECU and FI will not work.
Not sure what that voltage is for the PCX.
Also, adding kick starter cost money, adds weight, and drag on transmission parts.
So, if battery is dead, kick starter would probably not work anyhow.
Hope that helps.
Hope that helps.
Sean, who loves Hi-Vis everything.
2013 Red PCX150 - NCY V and DF, 11 g rollers, stock OEM belt.
2006 Wht. Burgman 650, 30,000+ miles, running like a champ..
Or not worry and if it does in say 8 years time buy another battery $30
I like the not worrying bit.
For most bikes anyway. My girlfriend's Metropolitan is EFI and has a kickstarter.
- GeeGusKahn
.Branyers wrote:For most bikes anyway. My girlfriend's Metropolitan is EFI and has a kickstarter.
Not really sure how well that works.
IF the scoot is fuel injected it uses a fuel pump to to get fuel to the injector under pressure.
The fuel pump requires a certain and constant voltage to pump.
If your battery is dead-dead, I don't think a kick starter would work.
Maybe on the Metropolitan they have figured a way around this, I don't know.
If your battery has enough voltage to work the fuel pump, the kick starter might work OK.
Early Yamaha c3's (fuel injected) also had a kick-starter but it was removed on later versions.
speedandstyle
Because this is the 21st century. Cars gave up on hand cranks in the 1930s. The question maybe should be why did it take so long for kickers to stop being fitted to bikes.Branyers wrote:Kickstarter. Why isn't it stock on our bikes?
Vancho
- Year: 2012
it is available and it works with flat battery on the PCX Fi engine
https://www.youtube.com/watch?v=N1ZYIzuvlaA
Now Pointing members to Vancho's Kickstarter thread (in our For Sale sub-forum):
viewtopic.php?f=14&t=7192
dick the den
Both my Suzuki,s address 110 uk have a kickstart one is a 65 year and the other is 2018.
springer1
Because after sitting for 6 months, my '70 Triumph will start on 1 kick. And I don't worry about the battery's health. Those Land Rovers that survived in the African bush had crank starters for the same reason - no battery, bad starter, no problem!speedandstyle wrote:Because this is the 21st century. Cars gave up on hand cranks in the 1930s. The question maybe should be why did it take so long for kickers to stop being fitted to bikes.Branyers wrote:Kickstarter. Why isn't it stock on our bikes?
springer1 wrote:Because after sitting for 6 months, my '70 Triumph will start on 1 kick. And I don't worry about the battery's health. Those Land Rovers that survived in the African bush had crank starters for the same reason - no battery, bad starter, no problem!speedandstyle wrote:Because this is the 21st century. Cars gave up on hand cranks in the 1930s. The question maybe should be why did it take so long for kickers to stop being fitted to bikes.Branyers wrote:Kickstarter. Why isn't it stock on our bikes?
You are just talking about reality, you’ll just upset them
70's Triumph that starts first time?
Wakey wakey, its time for your medicine.....
dick the den
But how many people would know how to use it,or what it is..?????speedandstyle wrote:Because this is the 21st century. Cars gave up on hand cranks in the 1930s. The question maybe should be why did it take so long for kickers to stop being fitted to bikes.Branyers wrote:Kickstarter. Why isn't it stock on our bikes?
Vancho
- Year: 2012
Use what? kickstarter?dick the den wrote:But how many people would know how to use it,or what it is..?????speedandstyle wrote:Because this is the 21st century. Cars gave up on hand cranks in the 1930s. The question maybe should be why did it take so long for kickers to stop being fitted to bikes.Branyers wrote:Kickstarter. Why isn't it stock on our bikes?
https://www.youtube.com/watch?v=N1ZYIzuvlaA&t=1s
Inoplanetyanin
- Color: WHITE
I carry motorcycle jumper cables, it's like a small size book.
The reason they don't come with them is that the added cost, complexity and weight does not justify based on the need.
The same reason applies as to why we don't have an spare wheel like Vespas used to have, or the kickstarter for a car.
