Final drive drain bolt and check bolt sealing washers.
frog13
Post by frog13 »
Anyone have Honda part numbers for the sealing washers for the final drive drain & check bolts. My Honda dealer didn't have them nor could they find them on the parts fiche. 2015 pcx 150. TIA
Slickvic
Re: Final drive drain bolt and check bolt sealing washers.
Post by Slickvic »
Looks like you need #9, found here: http://www.servicehonda.com/parts/looku ... K364E1710A
frog13
Post by frog13 »
Hmmm , probably the correct washer? , you'd think they would show the check / drain bolt and washers in the diagram (s) .....thnx for the info.
chucktuna
I'm up to 12 or 13 now...
Post by chucktuna »
Not so sure about the other link.
Since I don't have a 2015 or a service manual, are the drive fluids drained from here?
I know the engine oil is, but what about #19 or 20 or 14?
I think 19 and 20 are actual seals, so that's not them...
http://www.cheapcycleparts.com/oemparts ... -crankcase
mtheall
Post by mtheall »
Looking at both of these links and my service manual, I'm 99% sure you're looking for 90495-MN5-000.
frog13
Post by frog13 »
Thank you all. ......silly service department.
frog13 wrote:Anyone have Honda part numbers for the sealing washers for the final drive drain & check bolts. My Honda dealer didn't have them nor could they find them on the parts fiche. 2015 pcx 150. TIA
Sometimes these things aren't listed as they are just generic aluminium or copper crush washers
