oil change intervals
chet
Color: red
Post by chet »
i picked up the 2013 PCX 150 with 800 miles on it last week. i am curious with such a small oil reservoir and since the engine is under a more than normal load at times, does anyone change their oil sooner, i am thinking every 1000 miles or when ever it looks dark
Chet
Year: 18 300 xmax
Re: oil change intervals
I change every 4-6 months.....thats less than 1000 miles....everyone sees this diff, it is so damn easy to change, ill do it more often than manual says.....i run valvoline synthetic 10w-40
Manual says 5000 miles, you are just wasting the planet's resources and your own cash changing it any sooner.
Year: 18 300 xmax
I'm ok with that....LOL
Jge64 wrote:I'm ok with that....LOL
That goes without saying
Removing the oil change bolt too often, even with new crush washers seems not such a good idea.
iceman wrote:Removing the oil change bolt too often, even with new crush washers seems not such a good idea.
Why?
JohnL
Ozzie Old Fart
Ozzie Old Fart
Color: Dark Red
Post by JohnL »
you you wrote:[Why?
Your wrist gets tired! :roll: :roll:
Bidlack78
Post by Bidlack78 »
I'm planning on 5000 miles or yearly whichever comes first.
Done
Why - because it's silly tightening bolts too often for no good reason.
Eiron
Color: Poseidon Black
Post by Eiron »
gn2 wrote:Manual says 5000 miles, you are just wasting the planet's resources and your own cash changing it any sooner.
Agreed, along with your time (probably the most valuable expense of all ...)
Eiron
Post by Eiron »
chet wrote:... i am curious with such a small oil reservoir and since the engine is under a more than normal load at times, does anyone change their oil sooner, i am thinking every 1000 miles or when ever it looks dark ...
If you're worried about it, use synthetic oil instead of conventional oil & follow the manual's recommended 5000 mile oil change interval.
Eiron
Post by Eiron »
Why?
Isn't the engine case made of aluminum? Unlike steel, aluminum has a finite fatigue life. The more often you R&R the drain bolt, the more potential you have to damage/stress the drain hole threads.
Use better oil, give your engine better protection over a longer drain interval, change your oil less, and save yourself time and money. 8)
Eiron wrote:
Why?
Ive never had a problem Damage is much more likely by hamfisted tightening Mind you I use a vacuum pump when i can
Year: 18 300 xmax
a Fumoto or a Stahlbus oil drain valve eliminates the paranoia of the the drain bolt overuse. I will mount one, prob the Stahlbus, on my next change...I have used them on every vehicle I have owned for the last 10 years.
http://www.stahlbus.com/info/en/product ... ain-valves
@ 2yous, I finally got a vacuum pump. The one I showed you awhile back. I'll post a pic here later (in case ye ol mind forgot :lol:
WhiteNoise wrote:@ 2yous, I finally got a vacuum pump. The one I showed you awhile back. I'll post a pic here later (in case ye ol mind forgot :lol:
Excellent. Its one of those "why didnt I buy one earlier" things.
JohnL
Ozzie Old Fart
Ozzie Old Fart
Color: Dark Red
Post by JohnL »
Does the Stahlbus interfere with the oil screen/filter?
j.d.b.
Color: red
Post by j.d.b. »
No interference, it's quick-coupling valve that replaces the drain plug on the other side of the case.
