thanks pcx150man
iceman wrote:I believe people mentioned no need to change oil sooner than the recommended interval, but no harm if you do. That said, how have you changed both sets of oil thingies and not had the screen out once? (if I read this above correctly). You should have checked it when you first changed the oil yourself, just to make sure - no need after that as all the crud comes out in the initial use of the bike.
Do you have the owners manual? It has the service schedule and is similar across all age of PCX - try this
http://www.hondampe.com.au/docs/owning_ ... 5_2011.pdf
The belt needs inspecting or changing - it may last a few 1000 miles more.
The spark plug and air filter need inspecting, although only the air filter will need changing as it cannot be cleaned (it's sticky). The spark plug is cheap, about £5 but some have used the same one for a lot longer - if it looks fine and the bike runs fine, maybe stick with it but buy a spare!
FTFY.AustinPCX wrote: 1km = 1000 meters
12km = 7.456 miles
12,000km = 7456 miles
iceman wrote:I just took it as 12 thousand kilometer's
