Maintenance
iyernat
Year: 2021
Color: Silver
Maintenance
Post by iyernat »
Folks - Thanks in advance for your comments.
I have successfully changed engine oil and final drive oil.
I was wondering what else I could do (myself) without doing much damage and also preventing a bigger headache in the future. My pcx only as 3700 miles and what are the things I should worry about in future. I read about drive belts and it scares me to even touch those parts. BTW - anyone live in the Tampa FL area who could guide/ help me do some more preventive maintenance.
Any and all help is appreciated.
Thanks
Location - Tampa FL
Currently own: 2019 Honda PCX150, 2021 PCX
Have owned and sold: Kawasaki Ninja R500, Honda VFR 750, Honda Silverwing[, Honda ST1300
honkerman
Re: Maintenance
Post by honkerman »
iyernat wrote:Folks - Thanks in advance for your comments.
Thanks
Drive belts aren't that scary. It's when you get into the insides of the engine that it gets interesting.
Your owner's manual has the maintenance schedule listed. If you do not have one, google it, it's available as a PDF.
Otherwise, I'd check the following:
Tire pressure/condition
Rear brake free-play
Brake fluid color (if it's brown, flush it down)
iyernat
Year: 2021
Color: Silver
Re: Maintenance
Post by iyernat »
Can you please point me to any "how to videos".
Thanks
Location - Tampa FL
Re: Maintenance
Drive belt doesn't need changed till 12,500 miles so no need to bother about it for a while yet.
honkerman
Re: Maintenance
Post by honkerman »
gn2 wrote:Drive belt doesn't need changed till 12,500 miles so no need to bother about it for a while yet.
You're technically supposed to inspect it at 5k, but it's not that difficult. Just pop off the cover, make sure it's in good condition, measure it if you want, etc.
honkerman
Re: Maintenance
Post by honkerman »
iyernat wrote:Can you please point me to any "how to videos".
Thanks
Go out to the main forum, then to technical help. There is a How To sub forum there with walkthrough a and videos.
easyrider
Color: blk
Re: Maintenance
Post by easyrider »
I'm up in Crystal River.. If you can get it up here and Ill change it for ya.. Not a problem !
Re: Maintenance
honkerman wrote:You're technically supposed to inspect it at 5k, but it's not that difficult. Just pop off the cover, make sure it's in good condition, measure it if you want, etc.
Technically you're supposed to have a Honda trained technician at a franchised Honda dealer inspect it...
If you don't know what you're looking for to decide if its in "good condition" or not, what's the point of inspecting it...?
PCX belts last longer than 12,500 so just leave it alone till then would be my suggestion.
Other suggestions are available...
honkerman
Re: Maintenance
Post by honkerman »
That's how they make the money for sure.
If we're going to split hairs, belt replacement is after 15k miles per the 2013 owner's manual. Might be different for 2015 and newer PCX's
But of course, if one does not have the necessary skill-set and doesn't wish to figure it out and learn how to do the work themselves, they certainly can pay a technician to do it for them.
Re: Maintenance
The PCX I had was 12,500 so looks like it has been extended on later ones.
One attraction of the CVT in a scooter is the minimal maintenance requirement.
honkerman
Re: Maintenance
Post by honkerman »
gn2 wrote:The PCX I had was 12,500 so looks like it has been extended on later ones.
Mmmhmm. Only better motorcycle transmission for smoothness and maintenance is a shaft drive.
Re: Maintenance
Sadly shaft drive has just about been consigned to the history books.
Very few bikes have it now, in the 80s there were far more options.
