110/70/14 front tire
Hi everyone, I'm new to this, can anyone help me find a link to buy a 110/70/14 front tire,
I live in America and can't find any one that sells this size front tire,
Thanks for reading
Thanks for reading
- Ishkabibble
Re: 110/70/14 front tire
Michael:
It might help if you put your specific location in your profile, and added yourself to the Owner's Map. I'm sure WhiteNoise will be in here soon to let you know how to add your location into your profile, but you can check my sig to find out how to add yourself to the Map.
As for your tire selection, perhaps you are indeed too "new at this" to know that the size called for in the Honda Specifications for the front tire is 90/90-14.
http://powersports.honda.com/2016/pcx/s ... tions.aspx
I don't think the size you're looking for will work. Why on earth would you want such an odd size tire?
Actually, though the size you are looking for is larger than Honda's OEM, your suggested size will fit. I have a 120/80-14 on the front of mine. But I did note when I changed the front fended/mudguard, the tire had been occasionally rubbing the fender/mudguard. Sorry, but I don't have a source for them in America.
And yes, because we come from throughout the world, please do add your location (America is okay) even though you list in your first post. Once we move beyond the first post, we likely won't remember where you are.
kramnala58 wrote:Actually, though the size you are looking for is larger than Honda's OEM, your suggested size will fit. I have a 120/80-14 on the front of mine. But I did note when I changed the front fended/mudguard, the tire had been occasionally rubbing the fender/mudguard. Sorry, but I don't have a source for them in America.
- Ishkabibble
He's right. For some of us, the memory is the second thing to go...8701michael wrote:kramnala58 wrote:Actually, though the size you are looking for is larger than Honda's OEM, your suggested size will fit. I have a 120/80-14 on the front of mine. But I did note when I changed the front fended/mudguard, the tire had been occasionally rubbing the fender/mudguard. Sorry, but I don't have a source for them in America.
Since you're from Frisco, you might want to look up on the map to see who is near you, and have a meetup.
I can find 120/70/14 everywhere, I came across delitire.com and they have a 110/70/14 tire, only there's nothing to click on, maybe they are only wholesalers.
- Oyabun
- Year: `12,`15,`19
- Color: black&black
I run 110/80 14 at the front of mine. This is the equivalent circumference, with 2cm wider rubber.
Try Motorcycle Tire Maniac. I have the Heidenau K63 110/80-14. Gives me a better/safer feel for the road. I did this several years ago and I think, once I got the bead set, I had to deflate the tire so it would fit between the reflectors (or some bracket) It's worth the ride. Good luck in your search. RP
Thank you RP, I think I will do as you say as my search for the 110/70-14 front tire has only resulted in a 83.00 tire and 139.00 shipping charge USD.
Motorcycle Tire Maniac is 83.00 and 8.00 shipping, thank you so much RP, god bless you!!!
Your welcome. Hope the change out goes smooth. First time is always the hardest. RP
