is there a torque chart for the pcx?
eggman
like for instance to tell you how tight some bolts should be?
- Year: 26 adv 160
Re: is there a torque chart for the pcx?
I don't know if there is a chart, however every section in the shop manual at the beginning tells you what the torque spec is for every bolt that needs a spec. Shop manuals not expensive if you're in the United States. I got mine off of eBay for I think $30
- k2apache6.0
Hey Glen, since you have the manual could you tell me the torque of the clutch assembly large nut beneath the clutch bell? I just got the NCY Super transmission kit and as expected comes without litratureJge64 wrote:I don't know if there is a chart, however every section in the shop manual at the beginning tells you what the torque spec is for every bolt that needs a spec. Shop manuals not expensive if you're in the United States. I got mine off of eBay for I think $30
P.S. I still have those fancy brake adjustment nuts 4 U, we need to meet up soon if you're in tow?
My PCX mod build here..
- Year: 26 adv 160
The drive pulley face nut is 44ft lbsk2apache6.0 wrote:Hey Glen, since you have the manual could you tell me the torque of the clutch assembly large nut beneath the clutch bell? I just got the NCY Super transmission kit and as expected comes without litratureJge64 wrote:I don't know if there is a chart, however every section in the shop manual at the beginning tells you what the torque spec is for every bolt that needs a spec. Shop manuals not expensive if you're in the United States. I got mine off of eBay for I think $30
The clutch 'driven pulley nut is 40
The clutch outer nut is 36
I'm around after next week
- k2apache6.0
Cheers, I'll text you early Dec. I'll be getting one of those manuals next.
