I ordered a new competers NCY transmission kit for my 2013 Honda PCX150. I went on l in and found some videos on how to install the clutch spring pulley etc. Even bought myself a clutch spring compression tool. I have a couple of questions. ...in one of the videos it showed a small bag of tiny bearings that go underneath the spring where it goes into the pulley wheel. There was also what looked like a black plastic washer/ adapter that the bearings go into and then the end of the spring. My kit did not come with that small bag of bearings and it looks as if the spring simply goes into the pulled wheel itself. I'm trying to figure out if those bearings are not needed or they're not included into the kit? If they're not needed, do I need to grease the end of the spring where it meets the pulley and also the other end of the spring? Thanks,
Jeff
Ncy transmission kit. Now posted correctly
Re: Ncy transmission kit. Now posted correctly
Adonai1st wrote:I ordered a new competers NCY transmission kit for my 2013 Honda PCX150. I went on l in and found some videos on how to install the clutch spring pulley etc. Even bought myself a clutch spring compression tool. I have a couple of questions. ...in one of the videos it showed a small bag of tiny bearings that go underneath the spring where it goes into the pulley wheel. There was also what looked like a black plastic washer/ adapter that the bearings go into and then the end of the spring. My kit did not come with that small bag of bearings and it looks as if the spring simply goes into the pulled wheel itself. I'm trying to figure out if those bearings are not needed or they're not included into the kit? If they're not needed, do I need to grease the end of the spring where it meets the pulley and also the other end of the spring? Thanks,
Jeff
I've never taken apart a PCX clutch but I have other scooters. I've never come across tiny bearings though. Why not wait until your kit arrives and see what is in it?
The kit already arrived and did not have the bearings, the videos I saw online showed the kits having them hence why I was asking about it. Trying to figure out if they're missing or simply not needed...
Adonai1st wrote:The kit already arrived and did not have the bearings, the videos I saw online showed the kits having them hence why I was asking about it. Trying to figure out if they're missing or simply not needed...
I'd suspect not needed then?
