OEM Honda HP4M oil - Are yearly changes okay?
romnation
Are yearly changes okay on this oil if I'm only putting a couple thousand miles on the bike in a year or does this oil need to be change more often than this?
Re: OEM Honda HP4M oil - Are yearly changes okay?
romnation wrote:Are yearly changes okay on this oil if I'm only putting a couple thousand miles on the bike in a year or does this oil need to be change more often than this?
No.
romnation
No it does not need to be changed more often than one per year?you you wrote:romnation wrote:Are yearly changes okay on this oil if I'm only putting a couple thousand miles on the bike in a year or does this oil need to be change more often than this?
No.
Yes, once a year is fine.romnation wrote:No it does not need to be changed more often than one per year?you you wrote:romnation wrote:Are yearly changes okay on this oil if I'm only putting a couple thousand miles on the bike in a year or does this oil need to be change more often than this?
No.
