Scan tool interface to pcx
Mikes150pcx
Color: Metallic grey
Post by Mikes150pcx »
I hooked up my obd2 scanner to my pcx and now I can read live data and clear codes! At first I just jumped wired and a bit later I cut a obd2 connecter out of a junked Ford a wired it to the 4 pin diagnostic connector. It works no problem. Just so you know any obd2 can ascertain generic data by law and will interface but make certain you get power and ground right and the data pin to the correct iso. It's simple.
zroger73
Color: Bronze
Re: Scan tool interface to pcx
Post by zroger73 »
What OBD II scan tool are you using?
Yeah, what tool and wiring as others have purchased interfaces / readers off ebay and some work and some don't. Thanks!
bongski
Post by bongski »
Mikes150pcx wrote:I hooked up my obd2 scanner to my pcx and now I can read live data and clear codes! At first I just jumped wired and a bit later I cut a obd2 connecter out of a junked Ford a wired it to the 4 pin diagnostic connector. It works no problem. Just so you know any obd2 can ascertain generic data by law and will interface but make certain you get power and ground right and the data pin to the correct iso. It's simple.
Did you just directly wired the OBD2 connector to the 4 pin connector?
Sent from my LG-H860 using Tapatalk
Conelite
Color: Blue
Post by Conelite »
I bought the 4-pin to Standard OBD2 plug adaptor. Only issue is there is no data transfer. Wonder what pins he moved around. Im assuming its the data pin.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Gil
Post by Gil »
A wiring diagram would be great.
amin12345
Post by amin12345 »
Mikes150pcx wrote: Sat Sep 14, 2019 2:52 pm I hooked up my obd2 scanner to my pcx and now I can read live data and clear codes! At first I just jumped wired and a bit later I cut a obd2 connecter out of a junked Ford a wired it to the 4 pin diagnostic connector. It works no problem. Just so you know any obd2 can ascertain generic data by law and will interface but make certain you get power and ground right and the data pin to the correct iso. It's simple.
which OBD2 Tool are you using and the wiring pls?
pcx888
Color: pearl white
Post by pcx888 »
yea i would like to know too.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Oyabun
Year: `12,`15,`19
Color: black&black
Post by Oyabun »
I use a home made cable, and the cheapest ebay special elm327 clone Bluetooth dongle to connect the Torque app running on my phone to the bike.
Works like a charm.
