It was owned by a close friend of mine who sadly passed away due to cancer and the bike was laid up until Nov 2019 when I purchased it from his widow . Im not sure if it had been on a battery conditioner / charger during the period of no usage but it only had 106 miles on the clock when I took ownership.
I rode it a couple pf times in very cold weather in November , the idle stop system worked ok and then put it inside my un heated garage under a cover connected to an Optimate battery charger/conditioner. I took it out just after Christmas and the idle stop system was verty erratic - The green light would come on every once in a while and the Start stop system would activate at the traffic lights / junctions every other stop..I put this down to the cold....
Now today I went out or a 15 mile ride in temp of +10 deg C ...Dry and cloudy but not icy. I activated the start / stop system after a few miles of up and down steep hills - hoping that the engine was sufficiently warmed up. The green light on the dash came on briefly then went out...The start stop system would not activate.
The battery is fully charged and have checked the voltage which is around 14v...measured on a smart charger ...
All battery terminal connections were tight and I have no other devices / accessories connected - only a fly lead to an optimate
The local dealer says its probably the cold and if its not then dont worry however I like things to work if they are fitted.
The bike has now done 290miles from new....never been left out in the cold etc and always garaged...
My local dealer has gone back on his word stating that although its over a year old they were going to honour the warranty under the circumstances of my friends death and that the bike hasn't been used ....now they say the warranty is null and void...NICE !
So before I start looking further afield does anyone have any ideas as to why the start/stop system will not activate?
thanks in advance
