Does anyone know where the temperature sensor is located on a pcx?
My rpm usually is higher at cold start now it's just normal so maybe the temperature sensor isn't reading properly.
Does anyone know where is this sensor located?
Re: Does anyone know where is this sensor located?
If there aren't any flashing fault codes, its fine.
- easyrider
- Color: blk
Located in the cylinder head directly opposite side of spark plug.Also the idle air control valve controls the idle rpm as well.
Thanks mate, I washed my bike with pressure wash around the engine, unplugged and plug it back in, moved the cables a bit and now its back working properly.easyrider wrote:Located in the cylinder head directly opposite side of spark plug.Also the idle air control valve controls the idle rpm as well.
I drive in dirty roads I know sometimes dirt gets in the connectors and stop the sensors from reading, had this happen before and after 1 wash it fixed it, just needed to know where exactly it was so I could pressure wash that area and tingle with the cables and connector.
