Two metal tabs are exposed. Results are the rear brake lever does not activate the brake lights and pulling the lever in does not allow starting. The bike starts when closing the right brake lever.
Examination reveals no way to disassemble the lever housing and reinsert the accuator tabs. I did succeed in popping the fuse serving the blinkers and brake light when trying to do so. A new fuse solved the problem.
Has anyone experienced this problem? Any suggestions regarding repair or replacement?
The parts fische doesn't show separate parts. I have a sinking feeling a new brake lever perch with a new connection will be needed.
