School boy error after only 250 miles!
scott161023
Post by scott161023 »
So after driving my new bike carefully with all intentions of keeping it spotless for the first year at least, it's ended up skidding along the floor and messing up most of the panels on the right hand side.
The bike had the idle stop/start function engaged and I passed it to my friend who didn't realise, he grabbed the throttle and the bike has shot across the gravel. My fault for not switching the bloody thing off!! I could only watch helplessly as my bike and the concrete made that horrible grinding and scraping sound!
Anyway, I have bought the panels from thumpertalk.com in America and the service manual from sell.com. I do recall someone here mentioning a specialist tool kit (but I can't see it anywhere) as there are some really awkward parts to deal with. Could someone advise me what tools I need for replacing the panels?
Thanks, Scott
Taz
Re: School boy error after only 250 miles!
Post by Taz »
Why didn't the seat pressure switch stop this from happening?
khaosaming
Post by khaosaming »
scott161023 wrote:...what tools I need for replacing the panels?
Well, I guess you could try and find tools like these somewhere else (out of stock, discontinued):
http://www.amazon.com/Actron-CP5011-Pan ... B000VYBLJ4
Take a look here as well:
http://www.hondapcx.org/viewtopic.php?f=3&t=243#p2893
Courtesy of EddieC:
scott161023
Taz wrote:Why didn't the seat pressure switch stop this from happening?
I have no idea Taz! If I'm honest I didn't even realise the bike had such a function. It would have saved me a big headache if it did (work)
scott161023
Thanks for the quick reply khaosaming, I really appreciate it!
khaosaming
Are you saying that the bike was unattended, no driver on the saddle, with the side stand open and leaning on the ground -- yet it shot off from hibernation when your friend touched the throttle?
If so, that is really alarming and makes me worry. I think better avoid using the function until this thing is cleared and solved.
Hey Scott -- I'm going to move this thread to General, since it is not a how-to guide.
ben
Post by ben »
Seat switch must have failed, surprising as i had to glue mine down as it deactivated too easily!
st3v4nt
Post by st3v4nt »
Do you have the PCX 150 or PCX 125? If you have 150 (and probably new batch of 125 if Honda still sell it in your country), well for
economical reason Honda decide to remove the seat sensor.
scott161023
@khaosaming That maybe explains it. No the side stand wasn't down/engaged, I was balancing the bike by holding it from the back whilst my friend took it from the front. We were basically moving the bike through a tight gate so there wasn't room for the bike and the rider to go through it at the same time if that makes sense. Again I stupidly should have switched the ignition off but hey I learnt the hard way!
@st3v4nt I have the 125 and I bought it in England. I've heard from others that they have now removed that function?
haildamage
Post by haildamage »
like i said in the other thread, it seems like a stupid thing to do and we should know better. however, it sounds like something i would do. there needs to be a lot more warning about how to avoid this. just flip the switch to 'idling' when the engine is in engine stop mode and it wont start from the throttle if it too much to reach down and turn it off.
my seat switch doesnt seem to work, btw!
khaosaming
st3v4nt wrote:...for economical reason Honda decided to remove the seat sensor.
There's no idling sensor (2013 PCX150 illustrated):
Compare with this:
http://farm5.static.flickr.com/4116/473 ... 1408e4.jpg
Alibally
Post by Alibally »
My switch was disabled ages ago. I Have to stop at a set of lights pointing up a hill and if I was sitting back on the seat it wouldn't start by twisting the throttle as the switch must be a bit sensitive. I just stuck a bit of rubber on the seat so the switch is pushed all the time. You just have to remember and turn the ignition off if you get off the bike.
Kinda makes me glad I Don't have one (idle stop). Sorry for "accidental" accident Scott :( Good luck with the fixings (I've used the same orange tools pictured above to remove tupperware. Bought at Harborfreight in the U.S. 4-5 tools in the pkg., not costly at all).
Here is the link to the Harbor freight site. These are the tools I use. By the way, I have found that if you want to temporarily hide the scratches until it is convenient for you to change out the body parts, fingernail polish or even model paint will hide the scrapes. Hope this helps some.
http://www.harborfreight.com/catalog/pr ... egory/428/
Thanks Mel :) Scott's not in the US, but link may serve others in need this side of the pond. Or am I wrong? do ya'll have Harborfreight stores?
WhiteNoise wrote:Thanks Mel :) Scott's not in the US, but link may serve others in need this side of the pond. Or am I wrong? do ya'll have Harborfreight stores?
Ebay. They come from the same place. China.
figurehead71
Post by figurehead71 »
Sorry to hear about your mishap.
My PCX 125 eSP definitely does not have that switch under the seat.
scott161023
Thanks for all the advice everyone. I bought the tools for £3, including postage from china (ebay) and they have just arrived. I'm surprised at how sturdy they feel! Just waiting for the panels to arrive from America and then I can get on with the repairs!
Cracksta
Post by Cracksta »
Hi all,
since reading this and never had an issue I actually got the same this morning but probably figured out why.
I parked my bike up at work, idle stop kicked in, i normally then turn the key off but i just got off to give it a re-tweak at the parking, touched the throttle and the bike came alive. I was very surprised, pushed down on the seat to let idle kick in and it idled, hit the throttle and it woke up again!
So had a look around and noticed my seat wasnt closed properly, i can open it up without using the button, so I think this is what casused the idle to be pressed down. I closed the seat and presto, it wont wake up from idle unless i put weight on the seat.
So this is probably whats causing all these other issues with unexpected starts.
