Hi guys,
I have PCX 125, year 2011
Yesterday I changed damaged headlight with some aftermarket one from Poland. Among standard bulb lights there is some LED thingy lights. The trouble started when I switched on indicator. It stays on all time....but when I rev up the throttle indicator starts working normaly. Again, when idle, it stays on.
Blinkers trouble
Re: Blinkers trouble
It sounds like you are not getting enough current to the turn signal circuit until you rev the engine. Check that your battery is fully charged. I wonder if, with the engine off (key in ON position) and a charger attached to your battery, your turn signals would work properly?? Try that. If that works it might give you a clue.
Well, I tried with charger attached but no avail.
Battery full charged but problem persists.
