Just removed centre stand to lubricate it, found an easier way to keep the spring under control instead of using coins, no uk coins would go in! I used baling wire, spread the spring using flat bladed screwdriver and insert a two inch lof baling wire into each coil gap
It worked well, Hope this helps someone.
Centre stand spring
- Color: red
