european turn signals
- dasshreddar
- Year: forzaruckuspcx
Re: european turn signals
I think the rear ones do(brake and signals (one piece)), front ones you need a new headlight(non US).
- Bash On!
Looks like the US headlight has spots to install turn signal bulbs--you would need to drill holes in the back of the headlight housing to install bulb housing, and move wiring. I was looking at it to put LED warning strobes in those locations (for event work). Don't think it would be hard to put regular bulbs in, either.
2013 Silver Wing ABS (Black)
1971 BMW R75/5 (White)
i realized i meant the rear signals i love how they wrap under like that here in the us they are stalks that stick way out
DISOBEDIENCE CREW
I am guessing the the wiring connectors are different, so unless you have experience with automotive wiring, you might not want to do it as a DYI.
As well, just thought of this. If you take the protruding signals mounts off, you will likely need new plastic that is not US plastic.
