Today I noticed a piece of rubber sticking out from under the body panel just above the rear tire. It looks like a shield to keep dirt from getting on the engine. The one on the left side is hanging, and the one on the right side is gone. Time for a trip to the dealer. Just a heads-up for other Forza owners.
gn2 wrote:I found one of them undone when I got mine but I just connected it back on.
I can't figure out where to connect the other end. The only hole I can find is in a tab on the metal frame up under the plastic bodywork, but it's too big.
you you wrote:At least the PCX doesn't fall apart within minutes
No, it takes hours rather than minutes for the crankcases to self-destruct.
Both of you make me thanks, I needed that
actually my 2013 PCX 150 did have loose parts....some of the plastic was loose and I only discovered so because i did all my own servicing. some of the 6mm's and the body panel screws....but you know built in japan but assembled here so sloppiness abounds....
