slight vibration at about 68 mph...anyone?
MORON
Post by MORON »
Im am still in break-in...anyone getting or had a slight vibration starting at about 68 mph....feels like a loose belt or something of that nature...was wondering if it was part of the break-in process...
Mgalutia88
Year: 2013 PCX 150
Re: slight vibration at about 68 mph...anyone?
Post by Mgalutia88 »
you're feeling the rollers in the variator bouncing around. its similar to a rev limiter except you can change out your variator and weights to add another 10+ mph.
MORON wrote:Im am still in break-in...anyone getting or had a slight vibration starting at about 68 mph....feels like a loose belt or something of that nature...was wondering if it was part of the break-in process...
Should you be doing 68 when running in?
There is a bit of a buzzing vibration at higher speed, both mine and the demonstrator I rode did it.
It was worse on the lower mileage demonstrator.
Nothing to do with the CVT, its what single cylinder engines do.
MORON
Post by MORON »
man I don't like it at all....from your experience this is normal vibration??? bummer....so if I change the sliders like i did on my PCX (dr sliders) I can get rid of this??? which sliders to you recommend? thanks BTW for the advice....
MORON
Post by MORON »
gn2, I had a pcx which of course is a single cylinder motor and never had vibration...so I'm not buying the motor as a cause...unless there is a loose motor mount or some sort of defect in the drive train...I was thinking a loose belt.
Its normal for a single cylinder engine to vibrate.
Honda have done a very good job of isolating the vibrations on the Forza, you should try a CBR250....
Without actually riding your Forza there's no way to establish if what you are experiencing is the normal slight buzzing vibration or something worse.
Take it to the dealer and get them to check it out.
The PCX has much smaller moving parts, so creates less vibration to deal with.
How many different motorcycles/scooters have you ridden over the years?
~Cheap_Ride~
Post by ~Cheap_Ride~ »
Weird, My CTX700 doesnt have any vibration at cruising speeds up to 75. :roll:
~Cheap_Ride~ wrote:Weird, My CTX700 doesnt have any vibration at cruising speeds up to 75. :roll:
Must be a very different beast to the NC I rode, it was fucking awful.
DAB
Post by DAB »
CTX=2 cylinders
Forza=1
Totally different machine.
OP claims a slight vibration? not really sure what that is, all my bike have a slight vibration.
Other rides
Darth Emma
Post by Darth Emma »
I'd take it to the dealer and see what they think.
Rides 2014 Honda Forza, 2012 Honda Ruckus
MORON
Post by MORON »
yea I had a pcx 150 with dr sliders...zero vibration and an awesome machine....just a little under powered for me. taking the forza to the dealer.
V4 TRV
Post by V4 TRV »
Any updates?
I'm more than happy with mine and love the smoothness of the engine - should loosen up even more in the next 600 miles.
Mine has done about four valve thousand miles now and the slight vibration circa 68mph has definitely decreased.
alan
Post by alan »
hi new member alan I also have a vibration at around 70,i think its not bad so I don't worry about it,dosnt seem as bad as I get more miles.
Mine has nearly 6000 miles and the 70mph buzz has reduced significantly.
MrSuperchicken1
Post by MrSuperchicken1 »
I am just under 600 miles and have also noticed this "buzz" type of vibration at around 67 mph. I find it to be a little erratic, but not sure if it connected to a certain rpm, or what. I know with the PCX, it had a limiter at about that speed, but do I understand that the Forza does not have a limiter? It just puts out all it can and that is it?
Thanks.
AustinPCX
Post by AustinPCX »
Over 4000 miles almost all of it 65-70 mph, no vibration for me.
marley2011
Post by marley2011 »
Didnt know pcx went that fast presume yoour talking about the 150 .? As the 125 would be max surely.
AustinPCX
Post by AustinPCX »
marley2011 wrote:Didnt know pcx went that fast presume yoour talking about the 150 .? As the 125 would be max surely.
Not sure who this was directed to but I have a Forza.
willajabir
Post by willajabir »
Might have confused him (he is new here) by your fuelly post in your sig & your forum user name......
Several upgraders/converts since the forum started as PCX focused.
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
