How-To: De-badge the sidepanel emblems
dem0nk1d
Post by dem0nk1d »
This is a quick down and dirty to de-badge your PCX emblems
Tools:
1.Microfibre Cloth
2.Denatured Alcohol
3.Rubbing Compound
4.Fishing line
Lets begin!
Take that fishing line and get it behind the edge of the emblem. Pull it towards you with both hands, this will cut the glue from the emblem and body panel.
Now use your finger to rub, the rubber glue/adhesive off the panel as best as possible.
If the adhesive is being stubborn hit up the area with either a heat-gun or a blow drier. The blow drier is probably going to be a little safer for the noobs.
Keep working on it slowly
Once you have removed a good portion of the adhesive, you can saturate a rag with the denatured alcohol, then remove the access adhesive.
You can now see the emblem has been completely removed, but there is a ghosting effect from emblem and the sun. This is where you will buff out the panel.
Grab your microfiber cloth or old-white t-shirt and apply in small circular motions.
First application
Second and final buffing notice the difference between the first application.
Done.
Alibally
Re: De-badge the sidepanel emblems
Post by Alibally »
I use dental floss instead of fishing line but the results are the same.
Alibally wrote:I use dental floss instead of fishing line but the results are the same.
Old credit card works too.
I would have warmed the badge first with a hair drier
willajabir
Post by willajabir »
Yes, hair drier or heat gun and it peels right off.
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
I agree with using a bit of heat (hair dryer) first. As well, there is a product available in the US (and maybe elsewhere) called Goo Gone which is great for taking off sticky residue from labels and things like that, so it would work good if there is a film of excess glue.
wingz
Color: Dark Silver
Post by wingz »
Did you get someone else to do it? The reflection looks different to your avatar.
^ ^ :lol: I agree :lol:
Yes, a bit of a warmup with a twirl around of hair dryer. Me too.
;) Very good how to, done with care & w/great step by step pics. Thank ya!
dem0nk1d
Post by dem0nk1d »
too funny, i'm whiteboy. =p
khaosaming
Post by khaosaming »
Most stickers, adhesives and glue residues come off easily using olive oil, butter and a hair dryer. Oil dissolves glue.
willajabir
Yep, but the results of sniffing olive oil just aren't the same!!!!!
Larry
^^ :lol: :lol: ^^
You guys are on a roll!
