PCX 2014 how to detach windscreen ?
Hello all I've been trying to remove plastic cover around the front lights that covers the windscreen screws but no success. Anyone has already experiences with please ? It is different than older models. Thanks. P.S. I have prepared Ermax +25 to replace stock one on mine PCX150 2014.
I've already sold my PCX and swapped to NC750S DCT
- Year: 2014 forza
Re: PCX 2014 how to detach windscreen ?
Simple enough. If you look at the very front bottom of the windscreen, where the wind tunnel goes up the dash you will see two phillips head screws that hold the plastic strip in place, They are well hidden. Once removed the plastic strip will slide right off.
Yeah thanks I've already removed it and it is same as previous one.
