just got a new tire fitted and will be putting it all back together today...wana say thanks for the help i requested in taking the rear wheel off, now that i have the new tire ready to go back on i was wondering if anyone knew the torque numbers for the rear swing arm........the exaust bolts seem to be as tight as you can put them as it took a small pipe on the ratchet to get them off....OH!!!! and numbers for the exaust to motor would be great.........
thanks,
Chris Durand
						torque numbers for the rear swing arm for re-assembly
- chrisdurand
Re: torque numbers for the rear swing arm for re-assembly
chrisdurand wrote:just got a new tire fitted and will be putting it all back together today...wana say thanks for the help i requested in taking the rear wheel off, now that i have the new tire ready to go back on i was wondering if anyone knew the torque numbers for the rear swing arm........the exaust bolts seem to be as tight as you can put them as it took a small pipe on the ratchet to get them off....OH!!!! and numbers for the exaust to motor would be great.........
thanks,
Chris Durand
No problem.
What's a tire?
- chrisdurand
i am just asking for the torque numbers for reinstalling the rim and the swing arm and also the exhaust to motor nuts.you you wrote:chrisdurand wrote:just got a new tire fitted and will be putting it all back together today...wana say thanks for the help i requested in taking the rear wheel off, now that i have the new tire ready to go back on i was wondering if anyone knew the torque numbers for the rear swing arm........the exaust bolts seem to be as tight as you can put them as it took a small pipe on the ratchet to get them off....OH!!!! and numbers for the exaust to motor would be great.........
thanks,
Chris Durand
No problem.
What's a tire?
The rear hub nut is 118nm. The swing arm and exhaust bolts just tighten them up until tight.
- chrisdurand
thanks!! thats exactly what i did........so much better than asking me what a tire is.......Alibally wrote:The rear hub nut is 118nm. The swing arm and exhaust bolts just tighten them up until tight.
