Gauge Magically changed to Kilometers
For some reason on my stop to get gas today the gauge changed from MPG to KM. I've looked in the manual and there is no explaination on how to change it back. I've tried various combinations on the two buttons with no luck. Anyone with an idea on how to get it changed back?
- willajabir
Re: Gauge Magically changed to Kilometers
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
Thanks for the link. I tried that and it didn't work. Some magic combination I tried did get it switched back, though I was trying various things so I'm not certain what worked. But I think it was something like after the trip meter has been reset quickly hitting the reset button flipped it between the two.willajabir wrote:http://www.hondapcx.org/viewtopic.php?f ... ode#p36823
As far as I remember, the way to cycle through mpg, km/l and l/100km is: set the trip to A then press and hold the reset button.
Yes that is what I did. Wish it was documented in the US manual.gn2 wrote:As far as I remember, the way to cycle through mpg, km/l and l/100km is: set the trip to A then press and hold the reset button.
Press and hold the mode button until it changes back to miles. Same thing happened to me. Read my post in Technical section.
