simple power port mod to charge devices
- kcpcx
- Color: Candy Rosy Red
Power outlet added. Handy to charge devices. Parts available cheaply on Amazon. Power port unplugs to allow use of Battery Tender.
'88 BMW R100RT
Re: simple power port mod to charge devices
Yep - I copied from an earlier thread but same thing.
I added an outlet just above and to the left of the fuel door. It was simple to install and is waterproof. It is ideal when I need to plug something in for a quick charge while riding.
- ScooterMan
i need to do this. When I listen to music when I ride longer distances, it eats up the battery on my phone. I have one in my Amazon cart, just haven't ordered it yet.
2015 PCX 150 (White)[/color]
- ScooterMan
BTW, I've seen people install these in the glove box. Not liking installing them anywhere but under the seat where it's lockable with regards to charging a cell phone, or any other electronic device of value!
I thought about adding a lock to the glove box but that was a bit extreme. Maybe if it was larger and more useful.
ScooterMan wrote:BTW, I've seen people install these in the glove box. Not liking installing them anywhere but under the seat where it's lockable with regards to charging a cell phone, or any other electronic device of value!
I have run a usb wire from under the seat before and plugged it into an adapter in the 12 volt outlet. I did this while I was in a restuarant . The outlet is hot all the time. There is a hole in the hinge that a USB cable will fit through. I also sometimes carry a small rechargeable battery for recharging electronic devices. That way I can just put everything under the seat and go inside while the device is recharging.
