Recently I had noticed a rubbing noise coming from the real wheel when approaching standstill, like last few feet before stop. The sound is like a tire rubbing against the wheel fender, but that's not the case. I also had heard it when leaning in a curve without much throttle and there is rear suspension movement. I had not concerned much, but today I arrived home and smelled like hot rubber, rubber burn smell from rearwheel/CVT area.
I have no issue with acceleration, top speed, MPG. Bike is performing as usual except for that detail. Mine had about 3,000 miles.
Any one had presented similar experience.
Thanks!
Rubbin noise when coming to standstill. Hot rubber smell
Re: Rubbin noise when coming to standstill. Hot rubber smel
som'n aint right mac!
rubber is tire or belt right? you have any of dem oversized tires on that 2011
I need me some pants
- kcpcx
- Color: Candy Rosy Red
Sit on the scooter, engine off, in your driveway. Slowly walk forward while a helper watches the rear tire. Carefully look for anything contacting the tire.
Something might be rubbing that you can't see yourself because without weight on the scooter, the rear suspension is not compressed enough to rub.
'88 BMW R100RT
Thanks for the feedback. I will try in next couple of weeks as I have it stored now. FYI my scooter is stock, no modifications.
