tucano urbano grip
tucano urbano grip
Hi, I would like to ask which tucano urbano grip is suitable for Honda Pcx. Do I need one with weight end or one without?
Re: tucano urbano grip
I ordered some off ebay, the listing said for the pcx 125. after ordering them i read the entire listing it said "for scoots without bar ends" i have since installed them and they fit fine, no issues at all apart from sweaty hands when i wear my bike gloves.......no complaints there tho!dpcz wrote:Hi, I would like to ask which tucano urbano grip is suitable for Honda Pcx. Do I need one with weight end or one without?
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
- Year: Forza 300 2018
- Color: Blue
If you mean the bar muffs, it is the one for bikes without weights (even though the pcx looks like it does have them).dpcz wrote:Hi, I would like to ask which tucano urbano grip is suitable for Honda Pcx. Do I need one with weight end or one without?
Go to this page http://www.urbanrider.co.uk/bar-muff-selector then select Honda and you will see the list of part numbers.
Cheers,
Barry.
Yes, I Was confused whether that black ends are weights or not. Thanks!
