Stop n Go Tire Fix
tbln930
Year: 2013 PCX 150
Stop n Go Tire Fix
Post by tbln930 »
I just plugged a rear tire from a roofing nail. It was in a good place and the plug is holding well. Are these purely temporary fixes? On my cars I would call it a day but these mushroom plugs don't even have the sticky stuff on them.
SECoda/tbln930
kcpcx
Color: Candy Rosy Red
Re: Stop n Go Tire Fix
Post by kcpcx »
I've never had to plug a cycle tire before, but have done a fair number of such repairs on car tires. I've never had one fail.
Obviously, I'd be a little more concerned about plug quality on a bike versus a car, as the consequences of failure are greater.
Purely anecdotal, but I've heard the Dynaplug and Stop & Go kits for cycle tires are very good.
http://www.aerostich.com/tools/tire-rep ... epair-kits
http://www.dynaplug.com/products.html
Regarding sticky stuff, if you wanted to put a little sealant goop in there with the plug, this is generally regarded to be the best stuff. I don't think most of the plugs require or recommend it, though.
http://www.jensonusa.com/!wZMJtPucQ88FF ... aQod5owAFg
'88 BMW R100RT
tbln930
Year: 2013 PCX 150
Post by tbln930 »
Thanks. I plugged a lot of auto tires with the sticky strips and they worked well. These are the mushroom plugs that are supposed to be better. So far 5 out of 6 said go with it and watch the pressure.
SECoda/tbln930
To do a proper repair on a tubeless tyre it has to be removed from the rim, the interior inspected and if suitable for repair patched from the inside.
Any strips/plugs pushed through from the outside with the tyre still in place are intended as temporary get-you-home fixes.
tbln930
Year: 2013 PCX 150
Post by tbln930 »
That Stop N Go is a slick product the way it forces the mushroom plug head inside the tire.
SECoda/tbln930
fun2scoot
Post by fun2scoot »
gn2 wrote:To do a proper repair on a tubeless tyre it has to be removed from the rim, the interior inspected and if suitable for repair patched from the inside.
Agreed. Please note that even patching the interior carcass is not 100%. Patches can, and do, fail.
Get a new tire - your life is worth it. Take the old tire off, mend it, set it aside for an emergency-only spare.
tbln930
Year: 2013 PCX 150
Post by tbln930 »
Once I mentioned going on unpaved roads to a few seasoned dual sport folks a tire change became eminent.
SECoda/tbln930
ScooteringAbout
Post by ScooteringAbout »
Out of interest, where can I get one of these patches? be handy when I'm miles away from a garage.
aka DrewJW
tbln930
Year: 2013 PCX 150
Post by tbln930 »
I have this one. They work very well. Very compact kit. The only failures I heard of so far were user error or a steel belted tire cut the plug. The user error is normally plug not inserted fully or not seated (pulled back once in until the mushroom seats against the inside of the tire) after being pushed through. It is very easy to do with the special insert tool and instruction card included.
http://www.amazon.com/Stop-Go-Internati ... op+go+tire
DrewJW wrote:Out of interest, where can I get one of these patches? be handy when I'm miles away from a garage.
SECoda/tbln930
ScooteringAbout
Cheers, before i really pour on miles going up Scotland later this summer, best grab one of those.
aka DrewJW
