chattering,vibration noise from rear
Jenny
Year: 2010
Post by Jenny »
Hi all,my pcx 125 has chattering,vibration noise at slow speeds normally when slowing down,it sounds like its coming from back wheel area,I have seen other posts on this problem but not found any fixes' or cause.My husband has run the bike on centre stand and all sounds good,any advice would be appreciated thanks,the bike is 2010 model and has 5000, oil ,water correct level and not been raced around
Alibally
Re: chattering,vibration noise from rear
Post by Alibally »
It's probably just the drive belt vibrating. It's pretty normal. Mine does it about 10mph ish with really light throttle.
It the bike smooth enough? If the clutch judders the bike will vibrate as well.
Jenny
Year: 2010
Post by Jenny »
I've had the bike from new and it's only just started
Alibally
Post by Alibally »
It was a while before it started with my one as well. Obviously it's difficult to demonstrate a noise to diagnose it over a forum but that's normally the cause. There are issues with the rear pulley bearings reported by some people as well
For piece of mind it might be better to get a mechanic / garage to double check it.
Jenny
Year: 2010
Post by Jenny »
When you say rear pulley bearing,is that the clutch
Alibally
Post by Alibally »
No, not the clutch. It's the rear belt pulley the clutch bolts on to. The symptoms are more a rumbling noise if that's worn.
Do you pull away gently most of the time? The reason I ask is that the clutch can get glazed and cause vibrations when pulling away.
The noise a slow speeds tends to be a worn belt or rollers.
Anyone else want to chip in?
Rattling numberplate syndrome...?
ScooteringAbout
Post by ScooteringAbout »
Mine shudders when setting off in heavy stop start traffic, occasionally I will hear a chatter, and it's just the rear number plate surround. I've done 5,000 miles with it, and not a single issue. Just mentioned it to the dealer when I was in previously ( not had 5k service yet no point this end of the year ) and he mentioned they will check the rollers for flat spots next service. Whether their is an issue or not, just advise your dealer but don't push the issue, you have a warranty. As long as your dealer is aware of the issue, should something go very wrong, you are then in a good position.
aka DrewJW
Jenny
Year: 2010
Post by Jenny »
Thanks for advice,keep you informed when hubby gets time to look further into it
Jenny
Year: 2010
Post by Jenny »
Sadly no warranty left as it's 5 years old,I don't think Honda will suffer that
Jenny wrote:it's 5 years old
Check the centrestand mounts, they're prone to breaking.
Jenny
Year: 2010
Post by Jenny »
Will do thanks
