Hello! Do anyone of a place that makes a brake caliper adapter for a
Honda pcx150 with a 260mm rotor. Want to put on  a Brembo 4P caliper. I have a NCY fork.
				MKE PCX
Re: brake caliper adapter
Which Brembo caliper are you going to use?
Are you going to replace the master cylinder as well?
If you have success, I may have to follow in your footsteps.
				troy
 - Color: red
I think I found a adapter.  "Frembo" makes a adapter for Pcx stock fork to use a 4 piston brake,  100mm  pitch with 20mm shim for a 260mm brake disk! !!!  Still checking if it will work on my NCY front fork.
