Does anyone know how long the 'Oil Change Light' will remain on if I don't change the oil?
I did my first oil change before the required 1,000 km's, now that I have just hit 1,000 km the light has come on.
Oil change light
- PingGam
- Year: 2012 PCX
Oil change light
Current Scooters
2012 PCX 150 Black
2016 Forza 300 ABS Yellow
2012 PCX 150 Black
Re: Oil change light
I found this with regard to oil change:
"To reset the indicator, press and hold RESET button while turning the ignition switch to the ON position, and keep holding RESET button for more than 3 seconds."
- PingGam
- Year: 2012 PCX
Thanks will go and try it nowchicaboo wrote:I found this with regard to oil change:
Current Scooters
2012 PCX 150 Black
2012 PCX 150 Black
Did it work?
The oil light once lit stays on till it gets reset.
Once reset it will come on every 8000 miles.
If it gets reset after the oil change is done, it lights up after the next oil change is due.
