Regulator/rectifier
parkmoy
Regulator/rectifier
Post by parkmoy »
Anyone know which one is used on the PCX125 and where it is physically located?
sendler2112
Year: 2013 PCX150
Re: Regulator/rectifier
Post by sendler2112 »
The charging is done by the AC generator/ starter. It looks like the charging and rectification is controlled by the main ecu. Is your bike not charging? Have the battery tested. Most auto parts stores will do this for free if you bring it in.
http://www.hondapcx.org/viewtopic.php?f ... gram#p8138
parkmoy
Post by parkmoy »
Hmmm.... a little more complicated than I thought. The battery is fine, it's just a lack of charging voltage to it.
The AC generator / starter is referred to as a stator. It's on the right side of the bike, in front of where the swingarm mounts to the motor, and behind where the cooling fan shroud is. Disassembly is on pages 13-1 to 13-9 or the US service manual.
Are you having trouble with starting your bike?
parkmoy
Post by parkmoy »
maddiedog wrote:The AC generator / starter is referred to as a stator. It's on the right side of the bike, in front of where the swingarm mounts to the motor, and behind where the cooling fan shroud is. Disassembly is on pages 13-1 to 13-9 or the US service manual.
Only when the battery has gone flat :) When charged there is no problem.
Is it not charging or do you have a current drain?
parkmoy
Post by parkmoy »
It's not charging.
Could be a duff battery.
It's happened before on the PCX I think Honda got supplied a dodgy batch.
There's been a few replaced under warranty.
Taz
Post by Taz »
There have been a number of posts with duff batteries and a battery can seem fine when not under load but is still the cause. I would try a new battery first.
Your location is not listed in your profile... If you're in the USA, you can remove your battery and take it to a Wal-Mart. In the automotive section, they have a battery tester you can use for free to check if the battery is good or not.
parkmoy
Post by parkmoy »
I'm in the UK. The battery is fine, it's been tested by a specialist battery supplier. There is no difference in voltage across the terminals when the engine is running and revving therefore it is not charging on the scooter.
How old is it? Is it still under warranty? Electrical problems are very hard to track down, it might be best to take it into the dealer.
parkmoy
Post by parkmoy »
It's early 2011, no warranty. I think maybe take it to a dealer is the answer.
TC3
Post by TC3 »
parkmoy wrote:It's early 2011, no warranty. I think maybe take it to a dealer is the answer.
You sure? Uk pcx warranty is 2 yeqrs I believe
FritzPinguin
Year: 2013 PCX150
Post by FritzPinguin »
TC3 wrote:You sure? Uk pcx warranty is 2 yeqrs I believe
Warranty on the battery in Thailand is just 6 months :|
Bike history: Germany: Staiger 50cc 2-stroke, BMW 250 (from 1952, my age), Honda Dax ST70, Honda CB 125 (Twin), Honda CB 750, Kawa Z400j
Thailand: Kawa Zephyr 400, Honda Wave 110 S, Kawa ZX130, PCX 150 (as far as I can remember)
