Hi,
do you ride yours during winter?
Something like -10 Celsius Degrees. I went to moto shop but the blond girl obviously had no idea how to ride in winter cause she was offering me a normal hood... I got jeans with knee protectors and very good jacket but anyways.. Scooter. Winter. What do you recommend?
Regarding Tyres - what should i look into?
Winter Clothing and Accessories
- Color: Matt Grey
Re: Winter Clothing and Accessories
Hi Frantisek,
I do ride in winter (although this will be my first year on the PCX), but we don't generally get temperatures as low as yours. Minus 5 would be a really cold day in the UK, and last winter it only just got below zero for a few days - it was mainly wet and windy.
But when I ride, I'll wear leather trousers and a textile jacket with quilted construction-worker-hi-viz overjacket and trousers over the top (they are cheap and really effective), winter gloves and handlebar muffs, some sort of snood to stop my throat freezing and *definitely* a pinlock visor insert to stop fogging. at -10 I'd probably be tempted by handlebar muffs and heated grips.
- DAB
I spent 4 years working in Austria and suspect there will be many weeks where you will not be able to ride, no matter what tyres you have.
I would use a Theromscud, heated grips, large Givi screen and large handguards. With a thermoscud you should have a good quality textile jacket and then be good to go.
Other rides
- Oyabun
- Year: `12,`15,`19
- Color: black&black
I'm living next door between Slovakia and Austria, and rode all the way during the last winter on the PCX (except in sleet, during snowing and below -12deg C).DAB wrote:I spent 4 years working in Austria and suspect there will be many weeks where you will not be able to ride, no matter what tyres you have.
DAB is on the stuff. I use a thermoscoud, heated grips, boots, snowboarding gloves and the medium sized GIVI/Kappa screen. So far I managed without handguards - but might give them a try this year.
As for tires I use Heidenau K66 (these are used by most of my scooter courier friends during winter) 110/80R14 at the front and 120/80R14 at the back. If they will wear out, I'll probably change to K66 M+S Snowtex for winter, and keep using the Michelins for the summer.
Link for winter tyres.
Look at the bottom of the page for your county's flag to get a local site.
http://www.mytyres.co.uk/cgi-bin/rshop. ... zeugart=MO
The sizes are 100/90 x14 for the rear and 90/90 x 14 the front.
I've used them a few times and found them reasonably cheap. You will need to get them fitted if you can't do them yourself.
