Hi all,
I have just got my A1 licence (UK) which means I can now carry a pillion passenger.
I couldn't find anything in the owners manual about adjusting the suspension or pre-load on the rear forks.
Are there any adjustments I can make to my PCX to help with the extra weight of a passenger? Apart from tyre pressures of course.
Pillion adjustments?
- RideLondon
- alx123
- Bangkok Rider
- Color: Fast White
Re: Pillion adjustments?
I don't think the rear shock is adjustable. An aftermarket suspension designed for heavier load is an option though.
You might want to upgrade to a more comfortable seat.
- Oyabun
- Year: `12,`15,`19
- Color: black&black
The stock suspension cannot be adjusted for pillion carry - only aftermarket shocks have preload adjustment options.
However you might want to adjust the headlight once you're riding with a pillion - that can be adjusted behind the headlight as per the owners manual.
