Hi guys,
Anyone know what the normal amp draw on the PCX with all the lights on, engine on?
was about to get some heated grips but recall reading someone saying 5 amp was normal as there is a 10amp fuse?
The heated grips are 4amp at max setting so little leverage for the 10amp fuse?
thanks
whats the normal amp draw on the PCX?
Re: whats the normal amp draw on the PCX?
The circuit that drives the blinkers and rear license plate light is a 10a circuit, you should be okay tapping into that.
The concern in the other thread is that the stator only has an extra n amps of charging power, meaning if you exceeded n, your battery wouldn't charge, and you'd eventually run your battery to 0.
4A draw isn't high enough to exceed n (whatever n was), so you should be fine. Anyone else remember the topic Cracksta is mentioning? I can't find it.
Thinking I'm going to replace my winter gloves first and see how I go. Else I'll get some I am Christmas as it the current weather in the UK seems to push forward, guessing it'll snow on valentines day lol
