If you get bored and looking for some ideas to add to your Forza, here are some lazy man ways to add some stuff, These involve no cutting or removal of any body panels.Now my seat stays up without any stick and glides up without effort. Will be adding a brake light strobe and some headlight modulation in short order.
http://mimed.io/s/g5epjkmphuttkmm8cve1851qbk
New accesories/modifications
Re: New accesories/modifications
Looks like a Givi windscreen. Glad the cutting down worked for you. I need one that's taller than they make. Their "tall" is good for me up to about 55mph but at 70mph my head gets beat up inside the helmet.
Not sure what you did to fix the seat hydraulics. Is that a different support? If so, what kind and where did you get it?
I think I like the bungee mesh on the back of the seat, but your video didn't show how you mounted it. Fill me in?
- Color: red
If you want to raise the windscreen, I'd suggest looking into a Laminar Lip ("google" it). They make one for the Forza optional tall windscreen, which I have on my Forza...it works great...reduces the buffeting. Not sure if the Lip for the Forza tall windshield will be correct for the GIVI, but they make generic Lips for various widths of windscreens. They attach with a Velcro-like material (but stronger),have a range of height adjustments, and are removeable.Dufus wrote:Looks like a Givi windscreen. Glad the cutting down worked for you. I need one that's taller than they make. Their "tall" is good for me up to about 55mph but at 70mph my head gets beat up inside the helmet.
"....we get by with a little help from our Friend's...."
Laminar Lip for the Forza (Honda Screen) can be seen here: http://www.laminarlip.com/forza.php
If you like this type of idea/solution perhaps contact them? Ask about idea(s) of raising your Givi?
Peek here: Universal laminarlip's: http://www.laminarlip.com/cruisers.php
~Cheerio~
![Cool 8)](./images/smilies/icon_cool.gif)
~Cheerio~
- easyrider
- Color: blk
You can get these struts from Westmarine or any cabinet supplier. This is the one I used and I just drilled and screwed it into the side of the seat pan and then to the seat. Very easy.. Takes about ten minutes and not taking apart anything.
Apexstone 100N/22.5lb Gas Spring/Springs,Gas Struts,Lift Support,Lid Support
Force:100N/22.5lb (Per Strut);Length ( hole center to hole center) :10 inch
Support opens lids to a maximum angle of 90 degrees
Suitable for Cabinet,Doors,Box ,Trunk ,Container etc.
With 5 screws to fix bracket ; English Manual included
We provide liftime warranty
Size Name: 2pcs This Apexstone lid support can be used for cabinet door , ,trunk ,piano frame ,container etc.
