new motor
troy
new motor
Post by troy »
HI! I just installed a Yuminashi 164CC FLAT DECK BIG BORE CYLINDER KIT on my Honda PCX 150. I am using a Takegawa cam, what is the valve clearance you are using ??????????????
d.a.rous
Year: 2014 JF57(125)
Color: Carbonium Grey
Re: new motor
Post by d.a.rous »
IN: 0,10 ± 0,02 mm
EX: 0,24 ± 0,02 mm
YSS G-Euro XL Red shock
Dr Pulley SR2015 13g sliders
Dr.Pulley SP2015-AK sliding pieces
SH Clutch (Facilitated)
Malossi Clutch Spring (Red)
High beam Passing (Flash)
Low beam switch (on/off)
Oxford HG "Touring"
Drive Belt Cover + Swingarm (Matt Black)
Michelin City Grip
BPT7594
Re: new motor
Post by BPT7594 »
0.1 IN and 0.24 EX. That's actually for stock camshaft. No idea how it will work on that takegawa camshaft. If it makes too much noise try 0.05mm IN and 0.1mm EX.
Pcxdemon
Re: new motor
Post by Pcxdemon »
BPT7594 wrote:0.1 IN and 0.24 EX. That's actually for stock camshaft. No idea how it will work on that takegawa camshaft. If it makes too much noise try 0.05mm IN and 0.1mm EX.
Thats also takegawas specified valve clearance with their cam.
