Headlamp Bulbs
pcx888
Color: pearl white
Headlamp Bulbs
Post by pcx888 »
Hey guys i was just researching and it seems like hs5 bulb and ph11 are the same. Connectors are same but wattage different.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
Gil
Re: Headlamp Bulbs
Post by Gil »
I hadn't seen those before. The part of the bulb that plugs into the headlight is very similar, i'm sure that with some shaving ti will fit. Be careful though,
it might burn a fuse with the extra wattage that it needs.
Gil
pcx888
Color: pearl white
Re: Headlamp Bulbs
Post by pcx888 »
pcx888 wrote:Hey guys i was just researching and it seems like hs5 bulb and ph11 are the same. Connectors are same but wattage different.
The bulbs are little different too. One has painted end and one doesnt.
2011 White PCX
