Has any one had this problem? i just bought a 2018 honda pcx.
I was having some power problems (200 miles on it) at 38 mph.
Scoot would act like i hit the rev limter at 35 to 40mph.
So i looked at the oil catch?It was full of oil.Took off air filter oil ran every where!
Does any one had this problem? Any help would be great.
lots of oil in the air filter
- Office Minion
- Year: 2018
- Color: Dark Pearl Blue
Re: lots of oil in the air filter
If that was mine, I'd already be at the dealership.
2018 Dark Pearl Blue PCX150
2014 Glowing Red Forza 300
- Year: 2018
+1. Sounds like maybe they overfilled the crankcase oil ?Cube wrote:If that was mine, I'd already be at the dealership.
- Color: red
called dealer there picking it up next week will keep you up to date if i find anything out thks
- Year: 18 300 xmax
its an overfill
‘15 PCX build thread here:
- Color: red
i do not know the dealer put the oil in. I never checked it. On the phone he thought i may have a very serious problem ,but he is not sure until he looks at it .
- k2apache6.0
That's usually it!springer1 wrote:+1. Sounds like maybe they overfilled the crankcase oil ?Cube wrote:If that was mine, I'd already be at the dealership.
My PCX mod build here..
- Color: red
Mine usually has a small smear on the bottom of the air filter box never enough for it to actually flow in a dribble though! It's always done it
The dealer is supposed to check all the basics as part of the inspection - brakes, steering, lights, suspension and oil and other fluid levels. The bikes are usually suppled semi-assembled with just the odd wheel and other bit to fit at the dealship (or that's how it seems to be in one UK dealer I passed by) - or are they now %100 assembled on delivery to the dealer?
As Tom192 mentioned, and having recently looked at the air-filter for the 1st time in 4 years of use, I had a very, very small patch of oil along a few inches of the rim of the filter housing (internal) which may be from the couple of occaions I have put in a little too much, but only just above the full mark.
- Color: red
Thank you all so much. check the oil 3 times way too much oil in it you were spot on
guys thank you for the help
