Clocking Flange
Clocking Flange
Does anyone know if anyone makes a clocking flange for the pcx150. Looking to spin the throttle body 180 degrees ish.
Re: Clocking Flange
ruckswap wrote:Does anyone know if anyone makes a clocking flange for the pcx150. Looking to spin the throttle body 180 degrees ish.
Never heard of a clocking flange.
Re: Clocking Flange
Isn't that for a carburetor? The PCX has fuel injection.
Re: Clocking Flange
To raise/reposition Carburetor:
http://www.composimo.com/GY6-Flat-Intak ... _p_36.html
He has a ruckus(?), and is seeking a similar flange for the throttle body on a PCX(?)
ruckswap, would you please add your location to your profile so that we may better assist you. Directions are below my post to quickly get that done. We Thank You
Re: Clocking Flange
WhiteNoise wrote:To raise/reposition Carburetor:
Well I never.
Re: Clocking Flange
Yes, I have a ruckus that i am putting the pcx150 motor in. The clocking flange would turn the entire intake/ throttle body any where from 15-180° depending on where the holes are drilled. I am trying to keep the intake/ throttle body from interfering with frame/ suspension.
