How-to reset OIL CHANGE indicator
rizwisamad
How do you reset the "OIL CHANGE" indicator on the HONDA PCX 2016 instrument panel? Please check below link for a snapshot of the instrument panel.
https://1drv.ms/u/s!AurMpq4rHZ8ZgZQ3uuW_s2gz2tiwYQ
Thank you in advance.
- alx123
- Bangkok Rider
- Color: Fast White
Re: How-to reset OIL CHANGE indicator
Hold reset button while turning ON the ignition, hold for like 4 seconds longer after turning ON. Reset Done
rizwisamad
Thank you for replying fast, but that doesn't seem to work. any help?
rizwisamad
and do you mean the reset button on the speed-o-meter?
- alx123
- Bangkok Rider
- Color: Fast White
yes, the reset button used to reset the distance traveled. it should work
rizwisamad
Thanks, it worked, just for the other peeps to know, it will only work if the mode is in "TRIP" or "AVG", not sure which one but one of them and not the "TOTAL" mileage view. Thank you Again.
- alx123
- Bangkok Rider
- Color: Fast White
Glad to help. Cheers
kindly add your location on your profile too
rizwisamad
Thank you again and sure I will update my details.
Tip Teamwork
Appreciated
(Subject title changed. Thread to be moved)
PCX2016
- Year: 2016 Special
- Color: White Edition
Interesting, I do not see anything in the manual about an oil change indicator.. Does the indication come on automatically at the predetermined change interval?rizwisamad wrote:How do you reset the "OIL CHANGE" indicator on the HONDA PCX 2016 instrument panel? Please check below link for a snapshot of the instrument panel.
American in Cambodia !!!
rizwisamad
Not sure how it works, I bought it from one of my friend when it was done around 15,500 KM and I got the OIL CHANGE indicator when it was at 16,000 KM.PCX2016 wrote:Interesting, I do not see anything in the manual about an oil change indicator.. Does the indication come on automatically at the predetermined change interval?rizwisamad wrote:How do you reset the "OIL CHANGE" indicator on the HONDA PCX 2016 instrument panel? Please check below link for a snapshot of the instrument panel.
