A small problem about the keyless...
doletotodole
Color: WHITE
Post by doletotodole »
This morning , when riding, the keyless symbol started flashing on/off on/off, the symbol resembling the wifi logo.
It did not stop untill I got off, switched off, in this instance the PCX started beeping on/off, The beeping was stopped only by using the key.
What is the cause of that? Anyone konws?
Thanks.
Re: A small problem about the keyless...
Info in owner's manual?
Year: 26 adv 160
Change the battery in the fob and re-pair with the bike.
PCX2016
Year: 2016 Special
Color: White Edition
Post by PCX2016 »
I also wonder. However I notice when I make a stop, open the seat and walk away. I get like 10 or so beeps. Not sure what this means.
American in Cambodia !!!
Oldie
Year: 18 PCX 125
Post by Oldie »
If the key loses connection with the bike during a ride (could be deep in a side pocket of your jacket, for example) then the symbol will start to flash. Similarly, if the engine is running and you walk away from the bike it will start beeping. There are probably other variations built into the system but these are the ones that I've come across on the Forza.
