Hello guys,
I recently bought a used Honda PCX 150cc 2014, and lately I have a problem with the hazard lights, indicators lights and beam light. Occasionally they stop working. Indicator lights and beam light work most of the time but hazard lights don't work. No fuse is blown. Please help
PCX hazard lights / indicators lights problem !!
- honkerman
Re: PCX hazard lights / indicators lights problem !!
Get out the multi- meter and the wiring diagram and start testing connections.
Someone else had a problem like that and it ended up being being the switch. He took it apart and sprayed it with wd40 and it started working again. You have hazard lights on a 2014? Hmmm... I have a 2013 model in the United States and they didn't come with hazard lights, so I installed some.
imaginateca
- Year: 2014-2015
Hello. Here in Spain PCX 125 owners are receiving an official notification from Honda about a known problem on voltage in lights that can make them to stop working. We are required to go to the official service to make it repaired for free. Check it out with your official service as it could be your problem.
Enviado desde mi ALP-L09 mediante Tapatalk
More here: viewtopic.php?f=2&t=10001&p=133786#p133786
I received a letter informing me of the recall of the 2015 model. It was fixed in 30 minutes although the problem had not come up on my bike.
Lafree
I've been having problems for the last 2 years with this problem a new indicator switch fitted did not solve the issue Honda dealer said they though originally the battery was at fault low voltage I said it it has never failed to start so that's rubbish and when the engine is running the voltage increases now a recall letter scooter going in on Friday so hope this solves the problem 2016 model.
